why would anybody want to run points at this day & age?
I hated messing with them.....
I grew up with pionts..my vinage cars have pionts...like everything, set up right, good HT leads, correct condenser, correct wires and they run reliable and great for yrs
When one gets into higher compressions and higher octane fuels it is THEN one needs the bigger spark to ignite the fuel...higher the octane the harder it is to ignite.
There is nothing wrong with pionts dizzys whan applied to the correct application.
You will get far more issues using race track type dizzys in a street car..again wrong application for the component.
The ACdelco would be the most reliable and easest of all the dizzys I have come across.
connect the dwell meter, poke the allen wrench in, wind over the engine, set to 32
I keep a presetup points dizzy for the Camaro....HT leads coil, vac advance, the lot, and a ceramic GM Holden ballest resister ...
Something go wrong or suspect on the HEI...couple minutes to pull the HEI, drop in the points, plug in leads, fire up and
set total advance
