Dyno testing on Edelbrock intakes
1 reading
1.7K views 4 replies 4 participants last post by  chevguy65
I found this today while searching for intake info and thought it was interesting because I am looking to buy a Edelbrock intake next week.
That was some good testing..but remember it's only a 360" motor. More cubes can skew things the other way. We did a 400" recently with tests of the Dart air gap style dual plane and a Weiand Team G single plane. The avg power from 3000 to 6300 WAS about 4 HP better with the dual plane, but the avg from 5000-6300 rpm was 8HP better with the single plane. The crossover point for the single plane was at 4800 rpm and by 6300 rpm the single plane was up 20 HP and it just kept hanging on. At 6500 rpm it had only dropped 4 HP.
The point is that unless you have a REAL tight converter and no gear, WOT at 3000 RPM and below doesn't mean a whole lot. You're running around at part throttle at those speeds. Once you stuff your foot in it you're above 4000 RPM in a nano-second and it doesn't usually drop below that if you shift in the 6500 or so range.
Don't get me wrong, the new dual planes are great and run killer, but there is still a place for a good single plane on the street.
JIM
Yes sir! The sbc intakes were designed around 350's, and bbc intakes were designed around 454's or less. Throw some cubes beyond that, and those dual planes are choking them. Those motors need to breathe.
