If you have any old quarter mile speeds for Z/28's try the horsepower calculator for quarter mile speeds in mph. You need the weight of the car which is usually 3200lbs, plus driver weight. I think the mph method is more accurate, as the ET method requires a good launch, which most test Camaros had problems with.
The 327 Corvette with identical Cam and heads was rated at 360 hp. That's 1.1009 hp per cubic inch. If the 302 made the same hp per cubic inch it would make 304.178 hp.
I would think the 302 would be capable of making a little more hp per cube as it has proportionaly larger valves per cube. So, either the Corvette engine is over rated, or the 302 was closer to 320 hp on a good day.
http://sura1.jlab.org/~grippo/auto_noframe.html AUTO CALCULATOR PROGRAMS BY BOWLING
The speed calculator program at the bottom of the page shows with a 3400 lb car, if it went 107mph, it would have 325hp.
David
I think tire technology and traction play some part on this as well. Hence why slicks improve 1/4 mile time
The older I get, the faster I was!
[This message has been edited by davidpozzi (edited 05-11-2000).]
