early production 69 non X code Z28?
12K views 29 replies 13 participants last post by  78MBA
My trim tag doesnt have a date code. But my sequence # is 10293. With about 250,000 69 Camaros built between Sept 68 & into Dec 69. The math on that would put me around the the third week of production. The car I have has been restored and no build sheet was ever found. I was told by the last owner that the car is a non X code Z28. Ive only talked to one very knowledable person about this and he said "yes there was early prod. non X code Z28s in 1969. The car does not have the original motor or muncie. It does have the 12 bolt and multi leaf springs. Muffler hangers above the differential, power disc brakes. What do you guys think? Im just curious to see if any other clues may verify this.
What is the whole trim tag number? I think that's what's needed, maybe along with options, to determine if it is a Z. And as far as I know, production for 69's stopped at the end of Nov. 69', not December. Far be it for me to claim this as fact though, as I'm continuing to learn.
Look for the code (stamped numbers) on the right hand axle housing. It should have four leafs, yet the rear springs were probably changed during resto. There should be a exhaust bracket welded onto the left rear frame rail from the factory behind the shock. It is rectangular and has two holes. Do you know the build month and week stamped on the trim tag?
ST 69 12437 NOR102701 TR 727 7272 09C Im not much of a typer and couldnt get the trim tag to type right but this is everything thats on it Thank You
What options does the car have, be as specific as possible?
Leaf springs
Brakes
Transmission
Rearend
Factory A/C or no
etc...
Get numbers off any original drivetrain parts, I don't remember if you said if the car had original rear, trans, or engine. Can you pst any pics...especially of trimtag, vin?
09C on the trim tag would be your date code, September 3rd Week.
There is no date code on my trim tag. And according to my "chevy by the numbers" book.. on page 14 NOTE-There have been documented cases of trim tags that DO NOT have a month or week code. I just checked my car, no rectanguler bracket welded to frame, but there is a bracket welded to the floor pan with 2 holes and nuts welded to the back of it behind the left shock and in towards the center a little. Also I have 5 leafs, not 4!?
The rearend on my car may not be original. on the front of my 12 bolt are 2 sets of numbers and I cant seem to figure them out. H27B or H278? also 3894860NF or the first number could be an 8 instead of a 3. Ive read so many books regarding these cars and I find a lot of different answers from one book to another. November 69 could very well be correct, I was qouting what I had read. Thank You
#21 ·
The H278 number should be on the rear of the differential, not the front. This is the casting date, and decodes as August 27, 1968, which is correct for a September week C 1968 built car (your car). I don't know where the date "November 69" in your post comes from.
Bottom line, the rear end looks original and you need to find the application cone on the front of the right side axle tube to make an educated guess if this was an original SS or Z/28.
The 09C from the trim tag is the 3rd week in September. The rearend number is on the passenger side, front of the axle tube. The numbers that you found are only center section casting numbers, found on all 12 Bolts.
owns 1969 Chevrolet Camaro
This car is Hugger Orange with Black (original?) Z28 stripes. basic interior, PS, PDB. M21 case #3851325 P0928, tailshaft casing 3857584. Its got a 350 motor cast# 3970010 that Ive chased down with a TJY suffix and the outcome didnt excite me all that much. But that will be rectified before the sun comes out next spring!!! I cant think of anything else that might help. The tilt wheel is from a 70 Nova.
#12 ·
The 09C # is on the bottom row of the trim tag and I believe is the acc option code which if I remember right turned out to be standard ivory interior. I was all over that rearend and I know the numbers are supposed to be on the the front pass axle tube but.....I couldnt find anything. The rear is still on the car but I was right up in there. And no A/C.
#16 ·
take your back seat out and look above the x-brace, sometimes there is a code in crayon, my early 10a car has dg3 on it, standing for dark green interior x33. sometimes it starts with an x??. here's a photo
#17 ·
Take a wire brush to that axle tube. You WILL find numbers there. If you don't I would say it was retubed and it's probably from a different model car. I bet it is there though. Use a light also.
#26 ·
If the tranny is aluminum (Muncie) but the crossmember hole is oval, then it was either an SS350 or a L30/M20. (327, 250 hp, I think)[/quote]
1969 did not have an L30/M20 option, the LM1 was the continuation to the 1967 & 1968 L30/M20 option. The LM1 was only offered for about 3-4 months of the production run and offered a 350, 255hp. The LM1 used the L6 SBC crossmember used in all smallblock applications.
#30 ·
Unreal, I may be totally wrong so forgive me if I am but wouldn't a Z also have the same crossmember. According to CRG the L6 SBC crossmember was used on every smallblock application including the Z. I really don't know if there is a differnece, I'm just reading what CRG has. I guess there could have been two different crossmembers with different holes.
