Hello, I'm new to the forum and I've already done a 'search' for advice on fuel pumps, tanks, and line size- because I know everyone hates a noob who asks a question that's already been answered a 100 times.
While I did find a wealth of great information, it seems that every car has different individual requirements depending on horsepower and how it's going to be used primarily, so here's mine:
'67 Camaro street/strip (but rarely
496 ci (5500-6000rpm redline stroker motor)
Mighty Demon 850
Performer RPM Air-Gap intake
GM '781' Oval Port heads, mildly ported, one size bigger Manley Race-Flow valves, dual springs and full roller rockers
10:1 comp, all Forged rotating assy, 4 bolt main
Comp Cams 286H .556 lift
Mallory Unilite and MSD 6AL box
Hooker headers 2" primary to 3 1/2" collector with 3" Flowmaster exhaust
Richmond 5sp OD manual trans (rated to 600ft/lbs)
12 bolt 3:73 posi, moser axles, c-clip elim
Forged steel 1350 yokes and moser steel driveshaft
Radial T/A G-Force 275-60R15
Probably waaaay too much info:boring:, but might as well be thorough. Nothing psycho at all, just a stout, big c.i. 5500-6000rpm motor with roughly 500 hp/575 ftlbs and a beefy driveline that will withstand it (hopefully
So what I'm hoping will be enough is:
A new stainless stock-style tank with 3/8" sender line to:
3/8" stainless hard line to:
Some kind of high flow filter (stumped on this one- need at least 110 GPH on the suck side of a mechanical fuel pump
) to:
Either a Performer RPM mechanical fuel pump (110 GPH) or a Holley billet mechanical pump (170 GPH)- no regulators required for either pump to:
Some kind of line to the carb (braided -6AN (3/8") might look nice, or a hard line?
Maybe another high flow filter inline after the pump?
My biggest questions are:
Is 3/8" fuel line big enough?
Are those 2 mechanical fuel pumps listed adequate?
Since mechanical fuel pumps are 'suckers', I need the tank inlet to siphon from the top- no fancy sumps or tank outlets right?
Fuel filter suggestions on both the 'suck' and 'push' sides of the pump- how many microns of filtering is needed in each?
I have one of those 3/8" Summit fuel lines with a gauge and sintered bronze filter- are they too restrictive for my system? (less than 110 GPH?)
Will this fuel system be NHRA approved?
I'd really like to keep it simple and avoid electric pumps, monster braided lines/fittings, and fuel cell/sumps if possible. The stock 3/8" fuel systems were good enough for the old 6L6's, hopefully a few minor upgrades will be enough to support my 496?
Thanks so much for any advice! (and to anyone bored enough to read through my long winded post
Edit
Ooops
, I missed a big thread on 3/8" line not being big enough and unregulated mechanical pumps not good enough either. I don't want to go psycho on an overkill fuel system, but I don't want to skimp and riska burned piston either...
So how about:
1/2" hard line http://www.inlinetube.com/Preformed%20Lines/Camaro/67%20Camaro/Fuel%20Lines/CCF6703.htm
and a better 'race' mechanical pump with a regulator? (which one?)
Now the problem is fuel tank 1/2" outlet line, carb lines and filters?
Mighty Demon 850
Edit
Ooops
So how about:
