Fuels lines and AN fittings
2.2K views 10 replies 6 participants last post by  Shannon4570
Does anyone here have any experience using AN fittings to go from their flared fuel line to the sending unit and pickup with a stock tank? I have installed subframe connectors which preclude the use of a standard fuel line (no crossover point) so I will be building/routing my own. I am thinking I will route entirely along the inboard side of the frame rail but the standard connection at the tank I believe is typically a combination of soft fuel line and clamps which I would prefer not to do. Any help or insight would be appreciated.
That was essentially what I was thinking of but you verbalized much better than I could. So I would cut off the end of the fuel feed where there is the raised lip and use a compression fitting there, then run up and over to frame, use AN to flared end as you say and just reverse that configuration at the engine? I think I like it as it also makes the hard line quite a bit easier to fit as well.
Does anyone have any issues with the fuel line running directly under the upper control arm bolts rather than on the other side of the frame? Heat from headers and exhaust maybe?
Thanks again
I think the intent of running fuel lines on the outside of the frame is to protect it from a broken driveshaft, clutch bellhousing failure etc. It is safer....
Don
That makes sense. I am just not clear on how to get the flexible line to the other side as it is now uninterrupted with frame frame. I'll have to put some brain power on this one as it is an unforeseen issue which I am going to have with the brake line as well.
I believe you are over thinking this. As I understand it you are using the stock tank, sending unit and mechical fuel pump. This is a low pressure system that pulls fuel from the tank.
Compression fitting into the existing hard line over the rear axle. You could even slide the new flexible hose on and use a hose clamp. Follow to old routing inside the frame rail to the sub frame and fuel pump.
Trying to run outside of frame means crossing it twice. No need to imo.
. Trying to run outside of frame means crossing it twice. No need to imo.
GM engineers did it the way they did for good reason. Outside the frame rail is safer....
Antecdotal evidence that it is safe is irrelevant imho. This is a numbers/probability of failure issue and one person’s story of success is statistically insignificant....
Don
To join tubing to AN, you can use a tube nut and sleeve. Slide the nut and sleeve on the steel line, then flare the line at 37 degree.
Personally, I wouldn't use braided or unbraided hose, from front to rear, it is bulky and it is still a rubber hose internally.
I would bend up metal line from front to rear. Like Vegas said slide some rubber hose on the line to join to the pump and tank. Or you can use tube nuts and some push on fittings.
https://www.summitracing.com/parts/...BRB6EiwA3cV4Kt1idcdmL9cHepeYMnumwfmh65Q4D5uSl-HE0lZnmKzWMa0MteMzuBoCR_cQAvD_BwE
https://www.summitracing.com/parts/...BRB6EiwA3cV4KnVifHhKVLtSdtTLdG8e9Okwjfc-gMvldTphl1LKs6NIKCGLkulttRoCjAwQAvD_BwE
https://www.summitracing.com/parts/vpe-22006
Good Morning Mr. Tim,
One option that takes a little work is to install a through the frame rail fitting. You have to drill a hole through the frame rail or subframe connector. The fitting consists of a tube with two AN fittings on each side. The tube slides into the hole you drilled and two nuts hold it in place in each side of the frame rail.
https://www.ebay.com/i/362168883737?chn=ps
I did something similar with my emergency brake (parking brake) cables. I drilled a hole all the way through the frame rails. I welded a steel bushing inside the frame rail hole so the frame rail would not be weakened at the hole. In my case, I just ran the cable through the bushing. You would insert the through the frame rail fitting in the bushing.
If you own a pickup truck or another car with a full frame, crawl under it and look how the fuel lines are routed. It helped me to determine how to run my custom fuel lines. I looked under a 2002 Tundra and 2017 F-250 trucks. Since you now have subframe connectors, your car is similar to a full frame truck.
#11 ·
Merry Christmas everyone!
Sitting here stuffed and really enjoying my new laptop which allows me to watch Polar Express with my kids and work on the forum at the same time!
I really like the idea of the through rail fitting. Ultimately, I have to get to the outside of the rail as Don indicates for safety but would prefer not to to simply loop over the rail - doesn't seem very sano to me. The fitting which will allow a flex hose to flex hose to hard line seems ideal. Thanks much.
