Gaps at corner of windshield molding
18K views 37 replies 13 participants last post by  Steptoe
Hello. another newbie question. I tried a search, but I know unless you type it right you never get what you are looking for, so i figured I'd just ask in a thread.
I have a gap at the top corner on both the right and left sides of the windshield between the "chrome" molding strip and the roof. Similar issue but much less on the rear window. The rear likely can stay as is, but the front has me concerned.
I washed the car (which I own for 2 weeks) and no leaks on either glass.
Can/should this be filled in, and if so, with what. Black caulk or silicone or something (the car is black)?
While we are at it, I noticed the center 1/3 of the bottom front windshield molding goes pretty much straight across the windshield, leaving a small gap between the molding and the "grill" section between the windshield and the hood.
Is this normal, and can anything be done?
Thanks so much for helping a newbie!
Ron
The glass sealer, hopefully urethane, prevents leaks. The corner gaps you have don't. That's just bad bodywork like your door problem without pictures in the other thread in which you posted. Black caulk will do nothing except look like a butcher worked on the car. The cowl panel or "grill" as you call it is supposed to slide into the lower windshield molding clips to keep it tight against the molding. Buy a windshield wiper removal tool to begin resolving that issue.
That glob will also retain water and cause rust. These cars were not perfect from the factory, what your seeng may not be big problem. Pictures would help though.
The gray looking vertical line, to the right of the cowl panel and just before the chrome molding which is at the bottom of the windshield is the gap I was speaking about. If you look both above it and below it there is no way it can be moved closer to the windshield due to its concave shape there.
#11 ·
There are pins in the channel that the clips slide onto. The moldings attach to the clips. If there are no clips holding the moldings on, that is probably why the moldings are not tight against the channel. Pull them off and get some clips and then snap them back on. It looks like the top molding will twist into place once it is clipped, the other molding should slide up into place.
If I misunderstood you, and they are attached with clips you need a trim tool to remove the moldings with out damaging them. Most auto parts stores should sell them for not too much.
#15 ·
The previous owner said they are GM stainless and have clips.
If the clips are played out they won't hold tightly. Don't buy clips from vendors. Go to your jobber and buy good Auveco clips. I have boxes of different styles and a box of 50 is less than the vendors. You need to evaluate the cowl panel situation. No reason it and the molding cannot be adjusted. Buy a windshield wiper removal tool.
The moldings seem to be on there tight.
those appear to be aftermarket moldings, I can't be sure but they don't look like OEM GM to me. Anyone else agree with this?
If they are repops they are junk and will fit like crap. You will be better off with originals and trying to solve the problem but first get clarification on the moldings if they are repops or not.
I was told they are GM stainless.
Not sure Joe, was thinking repop, but can't tell for sure. The top molding looks kinda tweeked, but maybe just the reflection. Original GM don't fit perfect in this area either. Agree with Scott, need to remove the moldings and start over. Get some new clips.
Regarding the cowl panel/ lower molding gap, the clips there hold both together and are adjustable. The cowl panel actually should slide underneath the molding. You'll have to remove the cowl panel to tell, but hopefully there's still room for adjustment to move the clips and lower moldings down and to the front. That's assuming the hood/ cowl gap is good and cowl panel doesn't want to be moved back towards the windshield.
The cowl panel-hood gap is fine. It looks like the molding is too straight across the windshield and if it was more of an arc the problem would be solved there. How mould able are these molding pieces?
#12 ·
#13 ·
#14 ·
#16 ·
You are not going to solve the problems until you disassemble and fully evaluate the situation. I just had GM moldings off and on (R&R) two cars multiple times and they fit fine. The lead work on your A-pillar is not that great and makes the gaps worse. But they should fit better than they do. I see what appears to be a stud behind the upper molding and not sure what that shiny spot is to the right of it. Easy to tell if I popped everything apart.
Update: I got the cowl panel to move up and under the lower windshield molding. 1 problem solved...Thanks!
And yes sauron67mm, there is something behind the molding...maybe the clips? I will get the tool asap, but I am nervous about doing this. Is it pretty simple?
Ron
#23 ·
Take it to a local glass company and have them look at it. If you try to remove the trim yourself and don't know what you are doing you can end up with damaged paint and or trim. The glass shop does it every day. Ask them. Might cost close to nothing. If you do try to do it yourself put a bunch of masking tape around where you are working to try to prevent damage.
#24 ·
Damaged paint or trim IMHO is the least of his problem. I have busted windsheilds by chipping the edge of the glass with the trim tool trying to remove mouldings in the past. I fianlly learned how and then let my brother break my windsheild while he learned. :clonk:
Jeff
#26 ·
I would also consider finding GM moldings, they will fit better. I am sure if you ask around you can find some for decent deal. There is a guy on e-bay (or used to be) that was selling them all redone with dings removed and polish up for about $250.00 per set or for the front or the rear. Not bad deal at all I thought. He was in the Dallas area if you want to search e-bay.
#28 ·
Sure, that'd help. :) Factory gaps on these cars varied quite a bit and is reflected in the the allowable factory tolerances. Like those hood gaps I mentioned, 1/16 - 3/16....1/16 imo, is too tight ! Generally, most of us shoot for 3/16 + a red frog hair.;)
#30 ·
UPDATE:
Found a great glass shop. The owner has done many musclecars. He said my trim is GM original molding. He said the problem is the body work in the corners and nothing can be done at this point. The hood and likely the cowl panel are aftermarket and that's likely why the gap is bigger between the hood and cowl panel. The lower windshield molding cannot go lower then it is.
He also realigned my driver and passenger door windows, changed the weatherstripping between the side and rear side windows (that I provided), and he got the driver's rear window cranking without giving it a helping hand. All the windows crank/move like new now!
Ron
#32 ·
UPDATE:
Ron
GM molding below. I have dozens and they all have the bead. If yours are not repro, then the bead was obliterated during polishing. Your inner corner and bevel also do not appear to be a match to GM. No offense to the glass shop, but ask how the windshield was originally installed. There are many resto shops that may have incorrect info or do substandard work. Like the one whose botched metal work I'm redoing.
On another job, the upper moldings fit similar to yours on a repro roof skin. I had to mod both sides to achieve a proper fit. A previous CHL roof skin did not require extensive mods.
#31 ·
It doesnt matter if one has Gm or aftermarket... what does matter is the person doing the body work has the mouldings, and the wheel arch mouldings, then the bodty work is shaped to match the mouldings.
In the real world, on these old car , the odds are at some time each cnr has been rust patched and therefore must be reshaped to the mouldings.
#35 ·
Interesting! So you modified the body work or the moldings? And if it's the moldings, how did you modify it?
Wheel arch trims, window trims, are supplied to the person doing the body work and the body is matched to the mouldings regardles if orginal or aftermarket.
If one strips back an orginal factory body in these areas u will find a lot of lead filler, not just filling the seams but forming the moulding shape.
To modify the mouldings, yes would be possible, outlandishly expensive, and would be basically making up new mouldings to fit from scratch...not practical
We where matching body work on my camaro yesterday...rear window and wheel arches, front next week.
