The 10A fuse for the gauges is blowing as soon as I turn the ignition over to on/acc. I can't test to see if I'm getting 12V on the + prong of the gauge b/c the fuse blows soon as I turn the ignition over.
The speedo and fuel gauge lamps work fine. I know they're on separate 12V lines, but the individual grounds all feed back a common ground line - so I think the ground is okay.
I started chasing this problem b/c my fuel gauge doesn't work. I'm about 82% sure that it's the gauge end of the wiring that is the problem and not the sending unit, as I replaced the tank and sending unit recently.
Ideas?
Ideas?
