I was turning my 383 crank with a torque wrench set to 60 ft. lbs to verify TDC. I have six plugs out, with two others loose. I was using a piston stop and found it from one side and was going around to the other side when the bolt suddenly got looser. Now the bolt will neither tighten nor loosen, it just spins. I can’t turn it with my hand and I can’t pull the bolt straight out. A ratchet will spin it easily. Did I just royally screw something up? How do I get the bolt out? Thanks.
