Just received a new pair of Doug's headers # d308 and installed them in my 67camaro with power steering 4 speed. The upper fit is great around the steering box, but the collecter flange touches the floor panel and the reduced doesn't line up. With the collecter by a1/4 inch because of the tranny cross member. I raised the cross member with some nuts between the frame and cross member. and the smaller part of the reduced touches the cross member. I like that this headers sit higher up to give me ground clearance as my last pair would scrape on bumps anyone have these fIt Issues and what did you do, and how much space should be good clearance 1/8 I inch good
