hey i have a 68 camaro new 454 and with the bb frame mounts i have more than enough room for the hei, so i installed it and broke engine in now i saw on another post something about the resistance wire and being used for the points. i bought a new engine and light harness for my car and i cut end off the coil + wires and put a solderless connector on to hook up the Hei, now is this the best way???? i crimped both the reg wire and the resistance wire together in the connector. i have a mini starter and am not using the yellow wire that fed the resistance wire with more juice(i cut it back and taped it. so i would like to know if what i did is correct and will work for a long time or does the hei need a bigger wire for power???? also i just taped up the ground wire for the coil as the hei does not need one, please fill me in, thanks so much for all the help
Jake
motor seems to run fine, winds up to 5500 nicely but have not driven it as its apart ready to be painted and i have never driven as i got it 2 years agaon and have restored it to my specs not original, thanks
Jake
1968 Camaro convertible, 454,th400,3500 stall,8.5 10 bolt,3.90 gears
Jake
Jake
