intake and valve covers are off. Cam is not wiped checked out all the lobes. pulled out number 8 exhaust lifter and couldnt compress it. These are hydraulic lifter. Put it back in and turn the cam to where that lifter was at top of lobe and tightened the rocker nut and it just started opening valve and didnt compress lifter at all.
They all seem to be frozen tho...I pulled a couple out and couldnt compress them at all. But if I take them apart and drain all the oil out then put them back together they will compress. Is this right? Isnt the oil supposed to keep them from compressing but its sat over night so I thought the oil would drain out? Im confused and I dont know much about hydraulic lifter.
The lifters are BRand new they only have about 30-40 mins of run time on them but have been in the engine for about 3 years unused.
