Well after a long delay I finally got around to working on the car again after a long delay. I had the car sandblasted last week and found lots of surprises. Today I removed the floor and being that I’ve never done this before could use some pointers. I have the entire floor pan ready to go but the rockers and toe boards need work. I haven’t touched the rockers yet, mostly because I’m a little leery of cutting on them being it’s a convertible. At a glance it looks like the rot is mostly contained to the inner rockers.
My initially instinct was to replace the inners only since the outers look solid.
From what I’ve been looking at online, looks like you can’t buy inners only for a convertible? The other thing that concerns me is what’s between all the layer that I may not see by just replacing the inners.
To you guys and gals who've done this before, have you usually found that if you need to do the inners you are better off replacing the entire rocker assembly?
The other area I could use some guidance in is replacing the toe board panel. The footwells have the brunt of the damage (see the crude patch on the driver side) but there are some pinholes on the upper firewall too.
My plan is to replace the rockers first then the floor pan and do the toe board/firewall after. I want to leave as much support as possible to help minimize the chances of the body getting tweaked. I just want to make sure I’m not shooting myself in the foot by doing the toe board panel after the floor pan/rockers.
I appreciate the help with this project and please feel free to chime in with any other tips, comments, or concerns with that you are seeing! One of these days I’ll get around to starting a build thread to properly document the journey. Thanks!
