JUST RELEASED - 1970-81 Camaro Dakota Digital RTX Gauge Kit!
1 reading
2.6K views 2 replies 3 participants last post by  3d cad
Yes! The 2nd gen RTX is finally out!
Contact us for your Black Friday deals!
Styled after the original equipment found in 1970-78 Camaros, this kit fits a stock or reproduction instrument bezel. Side by side with the stock cluster, you’ll be hard pressed to tell them apart, until the key is turned that is. A pair of TFT displays can be configured however you choose, and late model drivetrain integration is straightforward. 1970-72-style bezel available separately; kit also fits 1979-81 bezels but does not fit Firebird.
The RTX series is the latest from Dakota Digital, focused on retaining that stock look without sacrificing the late-model features you love. Every effort has been put forth to incorporate OEM design elements regarding the layout, face styling and indicators. A casual glance may dismiss these as original equipment, but once you hit the switch and the LED backlighting comes on in your favorite color scheme, all doubts will be removed.
Starting from scratch, CNC machined housings are filled with electronics designed and built in-house, helping Dakota Digital once again raise the bar for aftermarket instrumentation. The high-definition TFT message centers can be fully configured to display just about any piece of information needed. As you’ve come to expect from Dakota Digital, the RTX series utilizes a central control box to make installation and setup as easy as possible.
