Leaf Springs!!!
6.4K views 42 replies 12 participants last post by  emdoller
I took my car out today to drive to work as its been a while and the weather is nice here in northern CA. The car drove great but when I got out of the car and did the glance over the shoulder I was reminded how much I hate the after market 3 leaf springs I have on the car because there's a substantial gap between the tire and the body (I really hate this look). By the way I did buy an after market pair of monos and they didn't fix the problem either (they were crap)
So my question is, can anyone recommend a leaf spring that I can buy and install with out modifications to the car that will get me back to stock level? I should have kept the original mono leaf springs and lived with the wheel hop.
It's a 68 327/275 car...
Thanks!!!
Ed
The 3 leafs probably did put you back at stock height or close to it. You probably got use to the height of the worn, tired, saggy monos that occurs over the 40 yrs our cars have been in existance. Mine were the same way. Keep your 3 leafs and put a spacer block on top of the springs. That will lower the rear end down. Might cost you $10 tops for a piece of flat stock from a metal supply shop. And not the cost of another set of springs.
Are your tires stock size or lower profile? I have a 69 so the wheel well opening is flatter than your 68 or 67. I have always thought there looked to be more space. Maybe check out othre pics of guys 68's with stock suspension. Maybe even check the wheel and tire section pics. Or you can go the route of a Hotchkis rear lowering kit. Also did you tighten the suspension down with the weight on or off the car? Maybe it never settled.
#14 ·
Ed, I have comparison pictures of my car before and after the 3 leaves in this thread. It's probably similar to yours but I'd shim the top to get the exact look you are after.
http://www.camaros.net/forums/showthread.php?t=179202
And they do settle some with time. Put a spare, full tank of gas and toolbox in the trunk (if you haven't tried that already)
Ed, yes. It will be a 1:1 change. You may need to go to all ubolts if you are using any tbolts now. Is the gas tank full when you took that photo? is there a spare in the trunk? Obviously you can't shim out a couple inches but I'd try a 1/2" spacer(shim) between the spring and perch and see what happens. Hard to tell from your photo, but as said, I don't think you are too far off from stock height now.
#19 ·
Thanks Tom. I just got home and measured the wheel well. Right now there is a spare in the trunk and I'm low on gas (~1/4 of a tank) and the distance from floor to the bottom of the wheel well is 28.5 inches. I looked in the assembly manual and it doesn't have that measurement as far as I can tell. What it does have is the distance from the wheel hub center 20" toward the front of the car measuring the distance off the ground. For my car it shows high 8" to low 9" which is about where it is if I'm measuring it right. So long story but I think you are right in that it may be close to "stock" height. It just looks wrong to me.
To answer your question, I have the stock T bolts. I may have to just live with it.
Ed
#21 ·
hahahah!!! What's funny is my darn cat has sat in there so you have no idea how right you are!!
Yea, it's ugly!! I'm just tired of buying springs and getting the same results. As far as originality goes, I'd like to keep close just because the car is pretty original.
Not sure what to do at this point...
Ed
#22 ·
I didn't see a tire size. The stock tire diameter was I believe 26.5" It looks like you have more than 2" from to of tire to fender lip. I don't know where you are but a good spring shop can re-arch the springs to whatever you want.
#23 · (Edited)
my tires are 245/60-14. I'm in northern CA about 30 miles east of sacramento. To get the springs re-arched, would I need to take them the car or take the springs off? My goal would be to get the rear to look close to the front which means I'd have to lower the car about 3" or so... can they do that? What kind of shop does this?
Ed
#32 ·
I should of kept my originals. If anyone has an original pair of mono shocks and want to sell them, let me know.
Nah, I'd work with the multi's, like Tom said above, they'll give a better ride.
This is just my opinion but, I would pull those springs, clamp the pack, remove the center pin and see which one of the leaves other than the main leaf has the most arch. Then have that leaf de arched by 50% at a spring shop(with a press not heat). I think that would give you a lower ride height when the pack is reassembled.
Also if they don't already have them, get the ends of the 2nd and 3rd leaves punched for teflon slider pads, they will help a little against friction when the spring compresses.
Don't tighten the shackle bolts too tight either and, use good lube with poly bushings.
You'll end up with a lower ride height and a smoother ride.
Keep in mind when you lower the rear the front will come up a little.
#35 ·
Is yours worse then mine?
What's crazy is the more I look into this just about every car that's not original seems to have this issue and generally seem to solve it by putting bigger wheels on the car. So either the pictures I have of original cars are bogus or no one knows how to make a replacement set of leaf springs that makes the car look original.
I'm far from being an expert on this by any means but it seems to me that someone should be able to make a pair of multi leaf springs that when I put them on my car the sit like an original car sat... call me crazy for wanting that!!
Ed
#38 ·
Hi Ed,
I think you should tinker with the springs to get the ride height you want.
Filling the gap with a larger tire/wheel combo will cost more money and probably give an image of an attempted "wannabe" pro stock look, which doesn't sound like you want that.
You could always spend money on the Hotchkis lowering springs instead of new tires;)
#43 ·
Got the car back today and am VERRY happy with my choice to have the springs re-curved. The shop that did it was AWESOME and located in Sacramento (Hanley's Blacksmith). Shan is the owner and is a car guy!
My goal was to the space in the back = to the space in the front and he nailed it. The back dropped 1 7/8". Now I need to get new tires that are the right size!!
Here's a before and after shots:
Before:
After:
