Hey everybody, brand new to the forum.
I am looking for some wisdom and advice on an engine build I am just starting out.
Here’s my situation:
I just torn down the engine in my Camaro to the block, and I learned that the block is a late 70s, low compression block with dished pistons. The exact part number on the pistons is “H580P .040”.
Now, I am pretty new to the whole engine building process but from what I understand they’re low compression, bored .040 over pistons. The engine had 58CC “416” casting 305HO heads on it.
I have a comp 268H cam I got for a steal, and I wish to run it. I have the option to either Buy a set of 64CC aluminum heads, or I have a friend that has a set of 56CC aluminum heads I could buy.
My main question is, do I go with the 56CC heads to boost compression for the cam? Or stick with the 64CC heads? I can try to provide any more details possible if needed.
Thanks y’all!
Thanks y’all!
