I'm trying to bleed my brakes; just installed LS1 brakes on all 4 corners of a 67 Chevelle.
I have the bleeder screw at the passenger side rear cracked open and connected to a reservoir of fluid with a clear hose. All other bleeder screws are closed and the system seems tight - no leaks.
As I pump the brake pedal, the master cylinder reservoir does not change - no fluid is going down the lines.
I've disconnected the line going to the rear of the car and blew 30 psi air through it.
I checked the rod between the booster and the master cylinder- it seems to have plenty of stroke ; about 1-1/2".
Do I need a hand vacuum pump to get the fluid moving to the rear brakes ?
:wacko:
:wacko:
