Anyone out there running roller tip rockers and have noticed them being a little noisy? I've got Edelbrock RPM heads and stamped steel rockers with roller tips. Every rocker makes a ticking sound? Not a loud clatter like the valves are out of adjustment, but a tick. I've re-adjusted the vavles twice so far to see if I can make it go away, but it doesn't? It's not an exhaust leak off the headers because I just replaced with new gaskets and and tightened and re-tightened the header bolts. The "ticking" is very noticable. I can even hear it over the rumble of the exhaust and idle, part throttle, and cruising speeds?? 200 miles on the heads and only 3,000 miles on the rockers.
Chris
Chris
