Generally a Performer is rated at idle-5500 RPM. If you are running it on a little motor like a 283 or 302, would that elevate the RPM range to a degree? In other words would it be good for 6000-6500?
Definitely NO. Go with the Performer RPM.Generally a Performer is rated at idle-5500 RPM. If you are running it on a little motor like a 283 or 302, would that elevate the RPM range to a degree? In other words would it be good for 6000-6500?
Yes tha orig. 302 intake is closer to a Performer RPM.So the original 302 Intake would actually flow quite a bit better that the original Performer?
