Sourcing 15x8 rallye with 4.75” or 5” backspacing
2.5K views 18 replies 6 participants last post by  unexpected_RS
Hi folks,
my current wheels have a 4.5” backspacing, but I’m still rubbing on bumps. I’d like to get the wheels tucked in a bit more with a 4.75” or 5” backspace. It looks like Vintiques made them at some point but don’t anymore.
Does anybody have a good source for those wheels with that backspace? Or do I need to have them custom made? I see this thread along those lines:
Okay, I think I found the right combo. 5” backspacing (can reduce that with a spacer as needed) in chrome:
Does that look about right?
That’s the same wheel I provided the summit link to above. Should be fine.
#15 ·
I installed a Wilwood kit, 12.19" rotors and 4 piston caliper (front and rear). The Wilwod add states "fits with most 15 inch wheels". They clear the aftermarket steel rally wheels I have. I have 15x8 in the rear and 15x7 up front. I have some pictures of the clearance somewhere on this site...
#17 ·
No spacers, except on the front, and those were not installed as "spacers". Wilwood recommends a steel plate between the aluminum hub and steel wheel if there is not a flat mounting surface on the wheel. Rallys do not have a flat mounting surface. The plate is a Wilwood item, I can look up the part number.
Here is the rear 15x8 wheel to caliper clearance, I have a shot from the front through the hole somewhere, so you can get an idea of the space between the center of the wheel and front of the caliper.
