OK, I have been over the wiper wiring and fuse and have never gotten the wipers to work until today. I pushed the knob to see if the washer pump would run and the WIPERS WORK WITH THE PUMP....LOW AND HIGH SPEED !! What the heck ??
The other issue is the glowing alt light. I put 2 different alts in it today and they all do the same thing, not that I can promise any of them are good, but the engine keeps running after removing the pos cable with all 3.
Then I was setting the idle, so I applied the park brake to hold the car against the trans and the ALT LIGHT GOT BRIGHTER WITH THE BRAKE APPLIED. The brake light comes on too, but is very dim.
Are all these issues related and if so is it a bad ground on the instrument panel and/or wiper switch ??
Thought I would throw this out for help before a tear into the dash....:yes:
