Winch,
Answers are embedded in [brackets]below -
basscat, thanks mucho. [You're welcome - this site has helped me more than I can give back.] That does help. I didn't realize the rear of the SFC had tabs that let it set off to the side of the bracket.
So one end goes into the front SF and you drill holes horizontally thru the frame and SFC on both sides and put long bolts thru both sides. [That's correct - don't forget to install the spacers to keep the SFC and frame from distorting.] And then the rear just sets off to the side and the tabs go over and attach to the same bolts as the spring bracket? [The tabs go under the spring bracket but are held in place by the appropriate spring bracket bolts. Except the one that goes through the frame channel.]
Now is that a coupe I'm guessing and what brand were those? [It is a coupe and they are from Jegs] I have a convertible which I understand takes some cutting of either the SFC or the floor brace. But I'm thinking I could make a custom connector that follows the floor out of regular tubing. That would help justify the $$ for a welder. [Sounds like a solid plan to me.]
[This message has been edited by basscat (edited 09-13-2002).]
