sway bars or not ?
2.5K views 9 replies 9 participants last post by  madcarson
do I need sway bars front and back ? Camaro has Caltracks,subframe connectors,alum.body bushings,Global upper frt arms,CE drag shocks frt and rear,17x335 rears,17x245 frts.:confused:
For street handling, you will want a good size front sway bar.
Firstgens with leaf springs usually don't need rear bars. Your best bet on deciding is to just feel how she corners. If she understeers (pushes out) in a hard steady turn (cloverleaf?) then a rear bar may help balance things out.
My car doesn't need one, she's pretty neutral and I can easily bring the tail out with some throttle.
You don't need sway bars. My car also has SFC's, Caltrac's, split mono's, drag shocks, etc. and I do not have a sway bar on the front or rear. If your car rolls too much for your liking on the street then put one on the front. :beers:
owns 1969 Chevrolet Camaro
If it's street driven you need a sway bar on the front at minimum. The bigger diameter the better.It controls body roll on turns. Leave it off and you will be able to tell somthing ain't right on a turn.Helps a LOT with high speed stability if you are, ahem, on a public road and it isn't a straightaway.
