What color is the 69 Camaro tach wire that runs across the fire wall by its self underhood.
THANKS RAYZZ MY CAMARO LIKES MY MONEY
If it helps any, my tach wire is brown on my 67Help pleaseI hope I can get an answer for this ? I plane to put this wire in later to night. I think it's brown and it requires you drill hole below fuse box to put in grommet to run wire Thur. The wire then gets taped to top of wiring harness over to coil in engine bay. Also this car is 1969 Camaro ss 396 with console gauges, Tach at steering wheel, cowl hood, AC and Power brakes. If any of this helps.
Also were can I get the sideways connector that is on end of wire at coil ?
Friday :beers:
