Happy Holidays,
I have a quick question is regards to the correct location to place the two marks on the harmonic balancer when performing the TDC test. I bought TDC tool from summit have all the plugs pulled, valve cover off and on the #1 compression stroke (up). Even pulled the dist cap to ensure rotor is pointing at #1.
I read bring the piston up until it stops then mark the balancer? Where does this mark get placed? Is this where the (0) mark on the timing tab stops on the balancer? Then rotate the motor backwards 180 until it stops again and mark where the (0) shows on the balancer mark again. Then divide the distance between both marks and assume this is TDC?
The car is 68 Camaro with a 6 3/4 balancer has the straight keyway to TDC line on the outer ring at the 2:30 o’clock position- or 2º before. Thanks as always!:thumbsup:
