Good stuff. I assume you guys who are installing them in a semi-permanent fashion with caulk/glue don't have any water leaks in your trunk? If you do, how do you handle that?
Let’s hope you don’t have rust out in the glass channel around the back glass…..although it is somewhat common. The lower portion of the channel can hold a lot of water and dirt.
The quarter panel is joined at the panel above the deck lid in the upper corners , and that’s an area that needed a little seam sealer also..( mine does anyway)
The also have a tendency to rust under the deck lid seal ( if it hasn’t been disturbed for years).
It could be just an old seal that has lost its flexibility, or installed backwards ( lip facing in )
You could , 1 get in the trunk and have a trusted friend run a water hose over the back glass 😐
It’s a tight fit for an old and tall guy
2 pull the back seats and look through with lots of light obviously in both cases.
