what do i need to remount the battery in the trunk? is there any kit or company i should call? does the ground have to be to the motor?
I haven't seen a switch like this. Why do you need to disconnect the negative cable? All of the switches I have seen are meant to be used on the positive side of the battery.Originally posted by Mark C:
If your doing this to run the car in NHRA events you'll need the battery disconnect switch that disconnects both positive and negative wires from the battery. That switch alone will exceed the price of the summit kit.
All the switch has done is taken out the battery in the parallel circuitry. The alternator is still supplying voltage/current for the rest of the electrical system, until alt field circuit is opened up, or its output is interrupted.Because if the engine is still running following an accident the alternator will continue to generate power even if you disconnect the battery. I don't believe it will if you disconnect it's ground.
I thought that was why you run a disconnect switch. If it is hooked up properly it will shut everything off when it is flipped.Originally posted by Mark C:
You can do the same thing by installing a switch in the output wire from the alternator between the alternator and the main splice that feeds the whole car. Either way you need two sets of contacts in that switch.
As far as grounding to the frame rail you can do that IF you use your old ground cable to connect from the motor to the front frame rail and something to connect the front frame to the rear frame or where ever the new negative ground cable is.
