I removed the rust touched up that spot below my rear window myself, it came out all right, you can't tell it's been done unless your right there looking at it. I also removed the rust from my trunk pan. I used a Silicon Carbide wheel on a drill and some sand paper to take iyt off. if anyone else plans on this, buy several whell kits, they wear out fairly quick. one trick to make them last longer is when they get hot and start to gum up, "sand" some cement with it and it will removed the gummed up part. I got most of the area done, so I sprayed it with several coats of rust inhibiting primer to be safe because of some of the pitts in the pan may have been hiding . Just put the splatter paint on last night, its been sitting since, air is 100% humidity and it's taking a loooong time to dry. If the rust inhibiting primer dosen't work, I I 've done it once so I'll know how to do it quick next time and I'll use POR 21. I doubt I'll have to those, the rust was just surface struff on the splatter paint.
So as of right now, my trunk looks like it's fresh out of the factory!
