Been trying to figure out why my turn signals dont work on my 67 RS. Emergency flashers work fine, but the left and right turn signals dont work. I've worked it to where I think its an issue with either the steering column switch or a wire is switched round in the steering column connector. The steering column switich is a new replacement from Ricks Camaros. Has anyone had any problems with these replacement switches? Whats wierd is if I apply upward pressure to the emergency flasher switch the left turn signal works fine. If i apply downward pressure to the emerg flasher button all signal lights blink. Dambnest thing. Any insights?
Also, another interesting thing is that when the headlights are on, the front partking lights are off. Is this right?
Thanks,
Eric
Thanks,
Eric
