I am installing a disc brake conversion on my '67 and have decided to replace the upper and lower ball joints.
While replacing the left upper ball joint I have noticed a crack in the control arm where the ball joint mounts.
The 2" crack runs from the outer right rivet hole,to the right and then turns inside toward the subframe.
Would it be alright to repair the crack by welding it,or should I replace the control arm?
