1 - 1 of 17 Posts
You mentioned that when you applied the brakes the dome light came on. It sure sounds as if the brake light circuit is not grounded properly and going to ground through the dome light. I bet they are on the same fuse. It's possible you have contact issues with the main wiring harness socket on the firewall, in which case it should be disconnected and inspected.
1 - 1 of 17 Posts
