21 - 24 of 24 Posts
The 275deh cam is a mild street cam good to 5700, I would try the Comp 230/236, it should make good power past 6000.
67RS STREET CAR, 502 PUMPGAS, HYD. ROLLER, TH350 w/ATI 10" 12-BOLT w/373 - 10.92@125.2 ON MOTOR, ET-STREETs w/MUFFLERS
Discussion starter · #22 ·
67rs502, That's a wicked combo you've got there - sounds sweet. BTW welcome to the site. The 275 DEH makes good power to 5800 as you say, but with a 106 degree LSA it's not quite as mild as you may think.
I guess that's part of the whole cam picture - the affect of lsa on idle and power band. The 282S and 294S has a 110 lsa which is wider than I've run before.
Actually, the 275DEH has 110 lca...the intake centerline is 106 (if installed straight up...cam has 4 degrees advance ground in)...this is the same with all high energy and magnum cams, plus most of the extreme energy cams.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
instead of opening the engine again why not put 1.6 rockers is there a performance curve in the dist. ? how about a 1" spacer under carb. maybe 90/10 still front shocks pully on alternator to slow it down a drag race still front end alignment maybe shorter tires for track to compensate for street gears what I am getting at there are a hundred things you might try before opening her up again take the front sway bar off at track check fuel pressure take the surrated edges off the a arm bushing so the front end act quicker most of this stuff is stock eliminator ideas to cheat a car in thinking is has bigger heuvos
21 - 24 of 24 Posts
