1 - 10 of 10 Posts
Stroker68
Heres my problem... Im replacing my standard grill and Im at the point of installing the side brackets. The problem is I forgot the correct way they go on. If anybody has a pic of them installed, it would help greatly. I've searched all over for an image and found nothing.
Thanks for the help....
They are side brackets that attach to the back side of the standard grill, and then attach to another bracket that is attached to the headlight bucket. My service manual doesn't even show them in the diagram.
Thanks for the pic ! I'm not too familar with the standard grill, but I do see those brackets (part # 3919180) in the Assembly Manual. They're shown with the 2 holes riveted to the end of the grille. The flat face of the bracket goes towards the front, 90* bend towards the back (engine side). I don't see where the slotted end attaches....thinking directly to the headlamp housing ??
Yes-- bolts to the headlight buckets and rivets to the grille ends. Rick's catalog has a good description of them... see link:
http://www.rickscamaros.com/camaro-grille-end-mounting-bracket-set-with-rivets-1968.html
Camaro Grille End Mounting Bracket Set, With Rivets, 1968
  • Reproduction Of Original
  • Mounts Grille Sides To headlight Buckets
This Camaro reproduction grille brackets has been manufactured to original factory specifications using today's modern manufacturing techniques. You will find the fit and function will work superbly for your restoration. In addition, using a reproduction grille brackets from Rick's will add authenticity and value to your Camaro.
If you look closely at each side of the grille itself, you'll see the two mounting holes for the brackets to rivet to.
1 - 10 of 10 Posts
