41 - 48 of 48 Posts
I’ve looked at the videos on YouTube and there’s a lot on 68 Camaro window removal and replacements and a couple on 67 installation(s). I’ve not seen any on how to remove the door windows on 67 Camaros. From multiple videos and great information from everyone commenting it looks like you have to pull the wing window to replace the door windows. Hope I’m not creating myself more work than necessary. I asked about pictures so I could compare to what I have because there’s 2 bolts that are very loose. The windows work great but looks like someone took a grinder to them by the rear quarter window on both sides. Again all your suggestions and help is greatly appreciated. Thank you in advance.
No you do not have to or want to pull the vent window to remove the door glass.
The vent window has to be rotated and would be next to impossible to rotate with
the door glass in place. This is my best recollection of the door glass removal procedure:
Remove the guide that presses against the glass. It's at the door top towards the door jam
area. Position the window at about 1/2 open. Unbolt the track from the window lower support.
Loosen the rearward vertical glass guide. Grab the glass and pull the glass up out of the vertical
track and back so the glass won't get hung up on the top of the vent window guide. When it's
about at the top tilt the glass inward slightly to clear the window lower roller. When I did mine
the window fuzzy's were removed. Like I said I'm going totally from memory which sometimes
isn't so good. I think Scared Shiftless has a youtube video showing installing. Removal is just
the reverse. Good luck.
Edit: Here's the install video.
Okay, I now have a '67 Bird in my shop for some mechanical upgrades and side glass installation. He has new glass and most of the needed hardware, but not all. These reproduction parts are going into the reproduction doors. :-/ I'll read the first page instructions and watch the videos posted above. But does anyone have an exploded drawing of the necessary parts?
Thanks to AZ_Bill and everyone who posted this information.
Hi all. Working on adjusting my windows. Thanks to all that have posted the resources.
Does anyone know what the gap between the weatherstripping and vent window should look like?
I've got my vent window installed and looking to ensure the gap is correct before moving forward with the rest of the window adjustments.
Thanks in advance!
41 - 48 of 48 Posts
