Hi All,
69 camaro with MKIV 427 (10.5:1 CR), M 20, air-conditioning, and MK VIII fan. The current radiator is Becool 10168. Radiator needs to be changed and somebody told me to get wider tube radiator (1.25 or 1.5 inch). With becool radiator temperature stays between 215-220 when it is 100 degree outside. I tried 160, 180, and 190 thermostat, and water restrictor and same thing. I am wondering If wider tube radiator will lower the temperature?
found Dewitts 32-1149022M, and Griffin 6-00048. Which one of them to choose? Or do you have another choice?
