Just curious what is the current take on Edelbrock products.
Reason for asking. I purchased a few Edelbrock products for some work I have been doing on my 67.
To be specific, a Performer RPM fuel pump - part number 1721. I has an issue with the first one I received. The pump arm was short, it was too short to contact the fuel pump push rod. Summit sent me a second and it is fine. I also purchased a Victor Series water pump, part number 88113. The backing plate on the water pump was loose and started leaking. I'll be honest, I did not check the bolts before I installed it. So I went back and read through the instructions to see if there was mention to check these - no there wasn't. Actually instructions stated to not remove the rear cover, there are no serviceable parts inside. I bought some other items from Edelbrock owned companies and had zero problems with those.
I am not here to bash Edelbrock. Maybe its just bad luck on two items. I guess I am curious if there stuff is considered "the good stuff". I am just a little bummed with them right now, I expected better, their stuff is not the cheapest out there and actually leans to the higher end of pricing. And I think is marketed as Made in USA
