Hello,
We’re having an issue with our ‘68 Camaro 396. The charging is showing 16V at idle. At times it will drop to 14.8 at load.
We have replaced the alt. once, the regulator twice, we’ve replaced the system with a new alt. with an internal regulator. It has new wire harness for the engine bay. We’ve bypass the horn relay. Removed the dash circuit board, the grounds are good. Changed batteries. Still no luck.
Any suggestions, thanks
