When I got this car it did not have a horn. I have pictures I hope I can put in this message. Wire by the grill with a plastic plug on it and then another piece of wire on that same plug that's cut off it's just hanging there. I cannot find any continuity or checking to see if it's the ground. What are the button on the steering wheel I've pressed the spring pen all the way in and then check to see if the wire by the grill was grounded and it was not. I think the spring on the steering wheel when you press the button it's supposed to induce the ground and the horn should have a hot wire already attached to the horn. I don't see anymore wires. I can run a hot wire to the horn no problem. My problem is getting a ground to the horn from the button when it is pressed. I don't see a method for posting pictures tto show you the horn assembly. The button has SS 350 on it.
I found the Gallery. The name is Jdh 67. You can see what I'm referencing above.
My first time trying this. Hope it works.
