Does anyone know the specs on the upper control arm torsion bar? Need to check for wear before replacing bushings. They look ok but would really like to know.
Asking about the cross shaft?Does anyone know the specs on the upper control arm torsion bar? Need to check for wear before replacing bushings. They look ok but would really like to know.
Never did until I got new upper tubular arms. Never wore.If they aren't new, it might be a good idea to change them.
Thanks, will paint and move on. Any hints on reassembly with new bushings?If you're asking about the cross shaft as Scott said, there's really no way for it to wear out. The bushings don't rotate on the shaft. There are serrations on the end of the bushing inner sleeve that bite into the shaft. The rubber between the inner sleeve and outer shell is what does the flexing when the end bolts with washers are tightened.
