I did some searches on this, and looked in the stickies, but didn't find a simple answer.
Situation is this: when using a single wire alternator most are very simple. Run one heavy gauge cable from the alternator to the battery. A second exciter wire to turn "on" the alternator, a wire run to a switched 12 volt source on the existing wiring. The exciter or "on" wire to the alternator pulls very low amps and can pretty much hook anywhere there is a switched source for 12 volts. Easy.
Question is, when doing this does the factory external regulator need to be bypassed?
I know there is a easy way to make your own jumper, or the aftermarket has a plug in jumper.
I will confirm with my alternator mfg, but appears all 1 wire alternators are internally regulated. Issue is not addressed in the install instructions.
For my particular installation, I will not be using any factory amp gauge or idiot light, so those circuits are not needed. I know the factory gauge and idiot light circuits are tied into the factory external regulator.
May be a stupid question and show my ignorance to the charging system, but my common sense is telling me to bypass all the factory charging system, the 1 wire should be stand alone.
