I just finished removing the stock 10-bolt rearend from my 67. Inside is an 8.2" standard differential. I wanted to upgrade to an 8.5" posi based on the info that I've been reading on this site. I don't have the tools to perform the task so I arranged for a local mechanic to do it. However, when I talked to the local Eaton rep, he tells me that the 8.5" won't fit into the stock 10-bolt housing. Is he right? Is there a different 10-bolt housing for the 8.5" differential?
