I have a new build 383 with 12:1 compression I plan on running 105 but could you run 93 octane. Reason I am asking car isn't driven much but if you was going on a cruise could you run 93.
Yep good reasoning for hi coms in a street car also used for trackSimilar one here. I had an 11.5:1 combo several years ago. I ran 93 octane on the street and I ran 110 at the track. I drove it all over for two years and went 11.30's all day at the track.
What is the point? just use 96, and mixing 110 the difference is piontless....93 octane works with 11:1
12:1 look for 96 octane or better.
Some 100 no lead and 93 premium 50/50 mix would work.
As would adding 110 octane race fuel as long as you don't have a catalytic converter.
And the chances are its not a daily driver and race fuel sours even faster than our modern unleaded causing even more issues.
The only time mixing fuels like that is with pre 1954 british vechiles that had a Cr around 5 to 6 to 1 and designed to run on 60 to 70 octane...which is lower than the US octane std....then one mixes about 10 to 12 % A1 Jetfuel with 91 petrol.
Keep it Simple...
So long as the DCR is not to high to cause detonation, run the octane for best performance at the track
For the road highest common pump fuel possble and drop the timing 3 or 4 degrees for the lower octane on the street.
Who the hell wants to be mixing up blends of fuel on hot days, knowing that u cant store much of the blended or unblended without it going sour.?
OR fill up at one pump then fill up at another, again not filling the whole tank because it will just sour before using it all?
And yeah I blend for my old british vinage cars so they run as well as they did when they came out of the factory..bit better really.
Detonation doesnt need to be audable, if u want that engine to last tune in pump gas uder power with a knock sensor and data logger OR keep pump gas for low rpms around town and the exoitic stuff for the track
Those who are running pump gas, do u KNOW these is no detonation? and how do you know? as the only reliable way is a dyno with knock sensors or data logger and knocksensors.
Yep sever becomes obvious, with auditable.. not so till too lateIf there was detonation you would see it.
Which is exactly what I said way back and above....I only ran pump gas around town. When I went to the track I ran 116.......When this motor was built I did not intend on using pump gas but the cam reduced the cylinder pressure
And that must have had a reasonbly mild to stock cam to???? to pull those pressures...I assume 215 - 230 PSI cold on the starter motor and std CR gauge?A previous version of this motor (11:1 with similar duration cam but 102 ICL) produced 215 - 230 PSI cold. I ran that motor on the street with 91 octane for years. It was my daily driver.
No, it was a Crower solid roller 264/274 @ 0.050", .630" lift, 106 LSA with 102 ICL. It closed the intake valve earlier than the cam I used with 13:1 SCR. I used the same gauge with both setups.And that must have had a reasonbly mild to stock cam to???? to pull those pressures...I assume 215 - 230 PSI cold on the starter motor and std CR gauge?
