Hello ,
I had a choice with my latest project , a 1968 coupe .
Spend 15 K USD on an aftermarket frame , or just add
DSE subframe connectors …
I was going from an SS350 with T350 and 10 bolt rear axle ,
to a GM crate 502 motor , a GM crate 4L85 E trans… , a 12
bolt Moser USA rear axle with 31 spline axles , 3:73 Richmond gears ,
a Detroit Eaton rear Diff. , and a custom 3” 1/2 “ shortened DS with
1350 yokes …
The added cost of changing the frame , ( 10 -15 K USD ) plus labour
did not cross my mind . The DSE sub frame connectors are more
than adequate for the job .
Just my 2 cents my friend .
Im running 510 HP , and 580 Ft. Lbs of torque.
Cheers , just let me know what your thinking of running ,
that you’d require a new full frame … An LS9 with a SC ?
