2" Cowl Hood BBC - Does 14x4 Filter fit?
6.8K views 16 replies 9 participants last post by  Harris Roc Malouda
#1 · (Edited)
Hey guys,
simple question (i searched the forum but didnt find specific answers):
Does a 14x4 Filter Element fit under the Stock 2" Cowl hood of an 67-69 Camaro with Big Block and Stock Cowl Induction Air Cleaner Assembly? Is it ok if it protrudes into the hole of the hood?
Stock Filter height is 14x3, so its just an inch more, but:
The additional inch gives room for a Stubstack and also I would use it with an K&N X-Stream Lid.
I got an Edelbrock Performer Intake which is about stock height. RPMs and Air-Gaps are higher.
Also: My whole Engine seems to be shifted slighty so that Edge of the filter almost aligns with the edge of the Hood hole.. Do any of you experience the same?
Even more: Does the X-Stream-Lid work positively in a Cowl Hood setup or is it counterproductive? I would like to know all your guys 2cents to this topic.
Thanks in advance for your help!
#5 · (Edited)
Thanks for the feedback guys!! Great!
I hear and read this and that:
- the Air Filter shoudnt protrude into the hood cowl because of stream interference vs: its an advantage
- X-Stream Filter destroy air stream (Better use closed ones) vs. they do work well
.. well ..
so i guess i just have to test myself.
What do you guys have to say about k&n's advice to have at least 1.5 inch distance between stubstack and air filter top to make it work?
Doesnt this requirement become irrelevant with an X-Stream lid since it allows air coming in direct above the stubstack? Thus 1 inch or even 0.5 of distance should be enough?
Anyone got some experience with this?
so tomorrow the 14x3 element arrives and i will check if the room situation allows for more.
I actually want a 14x4 filter cause it gives the stubstack some room.
But i want to use a 1 inch spacer as well..
So 1 inch spacer + 1 inch more air filter height might be too much?
Big block life is just big space problem life :D
Ok here is the video of Engine Masters testing 19 Air Filter combinations... the winner with gaining 3hp over NO(!)-Air-Filter:
A salad bowl :clonk:
just google:
Air Filter Horsepower Shootout! - Engine Masters Ep. 27
@1971ls6: yeah thats what i mean. Some make good, some make bad experience with these fitler lids.
I suspect its a matter of combination:
When making the lid a filter, you exchange that for flow across the base. This - in my mind - should only have positive results when there is room to breath ontop of the lid: cowl hoods. Whenever a standard hood is used with filtered lids, it should work counterproductive. Making the Carb/Air cleaner suck on the metall hood instead of only sucking in sideways, which is the only way in the first place. Thus just giving up flow potential.
The Engine Masters in Episode 27 made the same experience: Flow from above is better that across base, "as long as there is room/air". Since they tested on the dyno, this situation resembles rather an infinite large cowl hood.
So get this: They taped the 14x3 element off, forcing all the air only through the lid (giving up ALL the flow across the base), result: gain of horsepower. :surprise:
I will test my setup with and without filtered lid and experiment a little :stirpot: Once i get my AFR monitor i can see whats stabilzing and whats destabilizing air(/fuel) flow..
Thanks for your input!
#12 · (Edited)
#13 · (Edited)
Ok some feedback (plus setup stats because everyting is important here)
67 Camaro
69 BBC 396
Edelbrock Performer Intake (Edelbrock Performer 2-0 Intake 2161 = 4.85 Carb Pad Height)
--> For comparison: GM 3933163 Original 68-69 BBC Intake = 5.0" Carb Pad Height
--> For comparison: Edelbrock RPM(Air-Gap) both: 5.22" Carb Pad Height)
Edelbrock 1411 Carb (Conv. to Manual Choke)
1" Spacer
69 Cowl Induction Base/Flange/Seal
14x3 K&N Filter + X-Stream Lid
Result:
Hood closes, but there is probably only 0.25 inch of room left at the top edge of the flange facing the radiator side.
I will try to bend it a very little bit down at the front facing side and then attach the flange seal to it.
I looked into the cowl from behind the main window and can the top of the filter. I guess it could fit a 14x4 filter but then in would almost touch the cowl roof. So i am gonna let it be like this
But i am gonna measure again to make sure..
#17 ·
actually it depends on the engine/intake/filter combination. I did some comparing among camaro shops.
Referring to stock intakes with stock 14x3 filter elements and the stock cowl hood air cleaner assembly it is like this:
A 350/327 uses a wide extension belt* between cowl hood air cleaner base and the flange part
A 302 uses a narrow extension belt*
A 396/427 uses no extension belt, since its already tall enough. Just Base + Flange
Hope that helps
*= of course you could replace the belt height by using a Carb spacer for example.
I got a BB so i ran into a little space problem.
As it seems, my Intake is 0.15 inch lower than stock and with my 0.85 thick adapter spacer (resulting in +0.7 inch over stock height) the hood juuust closes with no touching of air cleaner metal flange to hood.
But when i put the seal on it, i can feel the rubber pressing against the hood when closing.
