Goin nuts trying to figure out best way to go. 67rs got a 450 hp 350 and strong 10 bolt with 3:73 gears. Getting mixed reviews between 2004r and 700r4. I like the idea of the overdrive but cant figure out wich is the stronger choice. Need help.
Trust me, if your 700r4 was well built, it will be able to handle . Look at your uncorrected numbers(what your motor is actually putting out in Colorado) on your dyno and not corrected for sea levels what it would put out somewhere else. There are guys running with a motor like yours from the same builder running 200r4's, from Transdepot, almost stock and neither one of those motors tore up their 200r4's ........ You'll be fineI have a 700R4 with 3.73 rear end. Stump puller but at the same time very "short" first gear as the 700's 3.06 first gear is way up there. Mine is stage-3 rated up to 700 HP but my engine builder that's building my motor keeps telling me that his engine will spit that transmission out in no time. At the same time the tranny builder says bring it on. :boxing: I think both are good transmissions. The place I got mine from only offers stage-2 200r4 while all the way up to stage-3 on the 700r4 if that means anything. Some good threads on here that will argue either way. Regardless, no matter which way you go, make sure you set that famous TV cable correctly. Make sure you get all the hardware to make the carburetor/TV cable geometry correct. If you don't get that part correct, you'll not enjoy either transmission.
So true, but there is finally a solution for that if anyone is interested. Monster Transmission, makes a spring extension that mounts to the end of the TV cable allowing the carburetor to achieve its WOT even though the TV is fully expanded. I thought I was the only guy with "my TV cable travel is too short" until this little gadget. I'll take a picture once I get my tanny back, as it can easily be reproduced....Also the tv cable can keep your carb from opening up to wot.
