Greetings,
First time doing this so excuse my ignorance:
I finally pulled the original intake and 2bbl carb off my Camaro and am having a hard time finding the correct parts/modifications needed to get the throttle linkage and TH350 transmission kickdown connected properly on the new stuff (Edelbrock Performer EPS intake #2701 and #1406 carb).
I'm thinking I could make this adjustable linkage from jegs work for the throttle side of things: Adjustable Throttle Linkage Rod - JEGS High Performance.
But the transmission kickdown cable is where I'm going down the rabbit hole. Thought I found one here, but after careful reading, it sounds like it won't work without modification on the intake I've installed. Lokar KD-2350U TH350 Kickdown Kit (speedwaymotors.com)
To add to my confusion, some places, like heartbeatcity, don't even say whether their trans kickdown is for a 2bbl or 4bbl (I would have thought that distinction was fairly important, no?): 1967-1974 Camaro Turbo 350 Automatic Kick Down Cable Assy GM - 1967, 1968, 1969 Camaro Parts - NOS, Rare, Reproduction Camaro Parts for your Restoration (heartbeatcitycamaro.com)
Anyone out there done a similar swap on a TH350/2bbl Camaro and can point me in the right direction? I searched the forum and the couple of threads I found made it sound like it's maybe possible to just buy the OEM style components for a factory 4bbl but I wanted to directly ask about that and get suggestions before running off and buying stuff that won't work.
Thanks in advance
Thanks in advance
