Hello everyone,
I want to check the timing and I'm unsure what timing would be best for an engine with specs like mine. After installing a new distributor the timing was set to 8° BTDC in idle. I have read several posts and articles about timing, but that left me not really certain about what timing would be best.
The engine runs quite well once it has warmed up, but after a cold start it bangs a little and procudes soot as if it runs a little too rich. That has started some weeks ago.
It is a 383 stroker with a Comp Cams Thumpr cam, Trick Flow aluminium heads, and it runs with 100 EU octane (which would be 93 US octane?). I drive it on the road only, no track use or heavy duty stuff. What specs have I to take into account when it comes to the best idle timing? I would appreciate any help.
Thanks,
Peter
Information of my setup in detail:
Distributor
Unknown
Distributor Advance Kit
Moroso Advance Curve Kits 72310
Timing curve with the installed springs is from 6° at 2000 rpm to 30° at 6000 rpm with 18° at 3500 rpm.
It's the medium spring.
Ignition Coil
PerTronix Flame-Thrower Ignition Coils 40001
Carburator
Quick Fuel Slayer 600
Cam
Comp Cams Thumpr, CS 287T H-107 MT THUMPR
Heads
Trick Flow® Super 23® 195 Cylinder Heads
Stroker Kit
Eagle Street Performance
Thanks,
Peter
Distributor
Unknown
Ignition Coil
Carburator
Cam
Heads
Stroker Kit
