3917293 heads
1 reading
17K views 1 reply 2 participants last post by  pdq67
I just pulled the valve covers off my engine to identify the cylinder heads. Looks like I've got the #3917293 heads (1.72 intake valves, 1.5 exhaust, 75cc chambers) :(
How much potential do these heads have with a little work?
Probably not worth the effort when you can more than likely pick up a set of either 1.94"/1.50" or 2.02"/1.60" valve heads for about what or maybe even less then it will cost to work yours over, imho.
And with all the low-cost, aftermarket heads out there you will be better off going with a set of them or at a minimum a set of Vortec's even with the cost of a Vortec intake, valve covers and rocker arms....
The smallest valve head I will run nowadays is the # -601, 1.84"/1.50" one off the 305HO motors if the CR. doesn't get out of hand? (And that's only on a small motor!!).....
pdq67
