new 496 the initial dynos show a flat HP curve starting at 5200 rpm and then dropped off quick at 5800 rpm. Initial pulls were PBM (Morel) street hyd rollers and Comp 928 springs (160#/354#)
The hydr roller cam has aggressive lobes so I swapped in PAC Beehives (160#/425#) and Morel Sportsman hyd rollers to eliminate any upper end valve float. Back to the dyno - picked up 14 HP at 5700 rpm and 25 HP at 5800 rpm - valve train now seems stable with the Morels/Beehives, exactly what I expected.
But - the HP "curve" is still flat from 5200 rpm and up
Torque looks OK - over 600 ft/lbs from 4000-5000rpm with a peak of 625
A Team Chevelle 489 with the same cam, same heads, same beehives is making 637hp @ 6,000 rpm. I am struggling to get over 600 hp and its peaking too low (around 5,500 rpm).
The upper end sounds cleaner with the beehives and easily revs to 6000 rpm - it's just not making HP on the top end.
Any ideas on what could be holding back the upper end HP
