do a search for threads from 5 or 6 years ago about motor mounts.
the 327/307 small block mounts put the motor a bit forward and to the right from where the 302/350 mounts are, so headers that were designed on a "mule" with a 307 or 327 will probably not clear the steering box on a car with 302/350 mounts.
on my Nova- a factory 307 car- Dynomax headers cleared the box with about 1/2" of clearance around the box- they must have used whatever small block powered car the local Chev dealer had on the lot to engineer the header, and it probably had a 327- but when i replaced them with a set of Hedman's- which were probably designed using a 302 or 350 powered car- i had to dimple the tube. an HEI distributor cleared the firewall with about an inch to spare on that Nova- but on a 70 i had many moons ago that was a factory 350 car, i had to mangle the firewall with a Ford Tool to get it to clear..
so, to summarize- if an HEI distributor clears, then you have 307/327 mounts, and Dynomax headers will fit perfectly, but Hedmans (and Hookers, i think) won't.
